LCD4config from BH 2.1.0 to 2.1.5
Contact99
Just would like to know a simple answer for this question as this weekend I'm finally replacing my 2.1.0 image in my Duo 2 with the Latest image being 2.1.5 (doing a total clean install since you cannot back it up from image 2,1.0)and what I would like to know is when I save my LCD4config file (It looks very good) and eventually send it back to the Duo 2 with clean install 2.1.5 will it be ok? if not what part of my LCD4config file will be no good? "example Picon's and or other"
thanks.
Use the LCD4linux own backup & restore function.
Picons are not saved, but if you keep them on a USB pendrive you'll not lose them.
Thanks Eragon. All my Picons are saved on a USB plugged into the back of the Duo2. Every time I manually modified the LCD I have always back it up on my computer. I did not know you could save the LCD4Linux through its own back up and restore . Will look at this option.
But at the end of the day can you still back up the LCD4config file on your computer and send it back to the duo2 once the image has been replaced
