Lcd4Linux config files for Open BlackHole 4.2.04 ( Vu+ Duo4K )
Note: As Solo4k has the same LCD size ( 480x320 ), this config files might working on this Vu+ Model too.
Some Screen Shots:
HowTo:
Install the Lcd4Linux plugin from the addons feeds.
Unpack the Lc4Linux config Zipped file attached "Lcd4Config_OBH4.2.zip", to a folder on your PC, and by FTP, send the both files to:
/etc/enigma2
After that "restart your Vu+ Duo4k", or if needed reboot it.
If not brings up LCD4Linux to yours LCD Duo4K display, go to plugins and search for Lcd4Linux plugin, that you might install before uploading the 2 files to your STB, and set it from "NO" to "YES".
I have set up my duo 4k with openbh and apart from kodi not working everything is running great. One other little issue that I have found is a problem with the lcd screen. It is overscanning at the edges so the image is going off screen. This is a problem using lcd4linux or standard skins because I cannot read some of the text.
