LCD4Linux for Vuo Duo 4K
Dickie
Since there is no thread for this hardware, can the configs of others models such as Ultimo 4K be applied?
Anybody have start is journey on it?
Thanks.
Thanks.
Yes, but you have to resize all config parameters to fit the size DUO4K Lcd screen has ( 480x320 ).
Take a look here --> https://www.vuplus-community.net/board/threads/lcd4linux-config-obh-vu-duo-4k.37974/#post-252912
The procedure is the same for both IMAGES ( Open BlackHole and BlackHole 3.0.8 ).
You can, if you want save on your PC a copy of the "skin_user.xml" located at:
/etc/enigma2
In any case, i leave here the original "skin_user.xml" file.
