Matrix10
LCD4Linux ONLY SOLO 4K
To start a new topic.
I think that the team members and others have even more configurations.
Thanks to @Ev0
How to install LCD4Linux on Solo 4K
Example : Weather in LCD
First, install Lcd4Linux plugin from the Black Hole server.
Then make a backup on your PC or rename orginal file skin_user.xml file in /etc / enigma2 to skin_user.bak
This is the original file for LCD in Black Hole image.
After that, put the files from my ZIP if you like to have Weather in LCD
Restart BOX
You can edit your weather City in LCD4Linux Settings plugin or you can edit file lcd4conf
and reboot.
Lcd4Linux using the same picons you use for skin
format 220 x 132
Notification
It is possible that after image online updates you lose LCD4Linux in LCD
In that case you have to re-insert skin_user.xml for LCD4Linux
in /etc/enigma2
Thanks to @Ev0
Restart BOX
and reboot.
format 220 x 132
Notification
in /etc/enigma2
