LED VU+ ZERO 4 K
ahczl12000
Hello
i received my VU+ zero 4k unfortunately the LED VU+ in front panel do not light.
after having flashed all the same but I'm afraid it will deteriorate with time
is it reparable or should I return it to the supplier?
Thank you
Can you not change the settings for the display in MENU --- SETTINGS ---- SYSTEM and there DISPLAY SETTINGS normaly you can there turn it on or off.
my question is the following :
will this demo fail in the future or not with this default?
knowing that it will take a lot of time and expense to return it to the seller
Most likely, only the lamp is defective.
If you do not mind it, according to your writing, everything else works.
