Librtmp1 Issue
bruuce
Hi all,
I have solo 2 flashed with the latest BH 2.0.8
Whenever i try to download any media plugin, the plugin is downloaded, it does not appear in the intstalled plugins and i get the following error while installing :
Configuring librtmp1.
Collected errors:
* pkg_run_script: package "librtmp1" postinst script returned status 1.
* opkg_configure: librtmp1.postinst returned 1.
I tried to use new librtmp1 always with same error... i tried many things but the error is constant...
Any help please
I get the error when I install librtmp1_2.4 * _mips32el.ipk a needy library for enigma2-plugin-extensions-iptvlistupdater_1.30. * _mips32el.ipk
yes.. it was the IPTV list updater... once you try to install it, you have this error that stays with you forever..
Forever? Oh dear, I've been having this problem for quite some time and with other similar IPTV plugins too I tried to install from *******. Anyone know of any way of rectifying this issue?
Hi all,
Collected errors:
Any help please
ive been getting the same so please some1 at bh hq give a answer if you can please would a reflash work and try and install again or have we got wait for a fix or not install it thanks.
