Light and Intensity
el_zari
BH Lover
Hello all, and sorry for my poor english.
When I bought a Vu Uno, display characters were bright blue, and with Bh Image has diminished.
Any info for Adjust the display luminosity?
Regards from Spain.
Regards from Spain.
I think you can setup the display into Image Settings (Menu -> Settings -> System) or via Blue Panel settings.
Thanks but not solution in this menu. Look this examples:
Before with original image:
After with BH Image: 1.6.1,1.6.2,1.6.3,1.6.4 and 1.6.5
Any ideas? how can I change it?
Regards from Spain.
Any ideas? is it a deffect o it´s normal? Please, confirm it!!
Don't worry, I think your display haven't any problem.
The pictures you attached aren't good for a comparison becouse their exposure and lighting are different.
I can assure you that since I installed BH, I have never seen that color on the display, Although not the last original image. Problems drivers? Something happen, of course....More than one has the same problem
Regards from Spain
