G
Godanapo
Guest
Hello everyone,
I'm a proud and glad owner of a Vu+ Solo2 and always used BH images, which is pretty perfect.
Anyway, now I'm facing a little problem with some .ts streams I have and I'm dont know why that happens and need to fix it, which should be easy because it should be missing some libs, I guess.
Some .ts streams are perfect (all OK, smooth and video/audio great sync), but few others I experience a completely unsync audio with a breaking video. I'll try to explain better, the breaking video is not smooth. It stops for a microsecond and continues over and over.
Why this happens? Should I install any special lib to fix this?
I'm not using ******* nor other plugins. I'm only using clean .ts streams
Hope anyone can help me.
Thanks
Thanks
