Livefootball Plugin
Geoff
Hope someone can help. I have a vu solo with blackhole 2.5 installed. The problem I have is that the box crashes when I try to look at the live scores on livefootball 4.4. The other options on the plugin work ok. I have uploaded a crash log.
Thanks....Geoff
LiveFootball 4.7
-fixed live scores bugs
-added missed day to live scores
-improved fixtures,results and stats screens
Installation:
from the files in the links down or from ******* server or from update button
download Livefootball last version from here
be sure about the release suitable for your box
last version 4.7 7-1-2014
Thanks Mfaraj57
i Getting error with 5.6 . Its making box crash.Anyone had this issue.
I didnt had problems with previus versions.
Remove until it fix ... don´t use it, cause it crash ... and give you green screen.
If you want know where football live is ... google for liveonsat
you have there all the information you need.
P.S. uninstall plugin ...
Livefooball last version 5.7 ( Fixed )
LiveFootball 5.7
-fixed daily soccer fixtures and stats
Installation:
last version 5.7 16/02/2015
Thanks Mfaraj57
[/QUOTE]
Attached last Livefootball plugin version 5.7
Can i play video supported by flash player in my cpu?
I am trying to see live match (pay web tv) that via cpu browser use flash player.
I wonder if i can set my box to stream straight to tv this type of football match.
