hello i have a vu+ duo2.
i try to install the black hole image -- version BlackHole-3.0.3vuduo2_usb_release_20161227_1d956ae.zip
i did connected 1 cable to upper connection tuner A and 1 cable to upper connection tuner B.
i have this lnb
question 1 -> what settings do i use for the tuner screen below.
i can only take 1 satellite for each port
question 2 -> is there a fast scan function in black hole?
Thx in advance
i have this lnb
Thx in advance
