Hi all, I bought a zero4k and trying to install BlackHole but I am having some issues, I see a Loading... (the zapper has this screen frozen even with normal boot without trying to install BH)screen and I can’t do anything.
Any help?
Thank you very much.
thanks angelofsky, changed USB sticker, now it works.
I used DCC and added a cfg file and synced but once I start the zapper I can see only the default CAM, I had a VU solo se, all worked well, now is there a new way to do that? (I transfer in var/etc)
Thank you very much
4) Discussions regarding, pedophilia, pornography, piracy (keys, emulators, card sharing,
softcams, serial, crack warez) and to any debate illegal under existing laws are not allowed.
Recall also that it is illegal to reproduce your subscription to any Sky decoder IC that
has not paid the royaltes to NDS Group plc.
In order to prevent any discussion about the possible unlawful use of the receivers, it's forbidden
any debate about the smartcard reading and encoding systems.
sorry I didn't know Mick.
Can I add a USB DVB-T sticker to watch terrestrial channels? What do I need to do (just insert the USB sticker in the zapper or do I need to download new drivers considering I will use the sticker connected to old VU SOLO SE?)
If I were you, I wouldn't buy the new "black" one. I've got Gold and there are only a couple of useless channel it can't get. Plus other limits, by the black one...
