Logfile for package installations
skybandit
Is there any way to get BlackHole to create a logfile when installing packages?
I'd like to figure out why a package doesn't install when it appears to install correctly...
You should try to install that package via telnet session on your box
How do I do this?
I assume that I copy the *.tgz file to /tmp and run gzip, but where should the archive be extracted to, and are there any specific options I need to use?
The installation is package-ependant.
You can use the following command to uncompress the pacakge and see what it contains:
cd /tmp
tar xvzf file.tgz
Next, install by hand the files.
