I have occasional problems with recordings, where the file created by a timer event is empty (zero bytes). So far, I have no idea why this is. The big problem is that most recordings are fine and there seems to be no pattern to the occurrence of the zero-length recordings.
What logs are there that are, or could be, relevent to timer events, or what could I additionally log (and how?) to view as much event history as possible e.g. something like Windows Event Viewer? I am happy to consider writing code or scripts to do this.
Thanks
Vu+ Duo2, BH 3.0.2, internal 1T HD
Thanks
