logos and transcoding
Install the image you download from this forum.
Then just run image update to get last version of 3.0.9
Update image by pressing Green Button >> Yellow Button and choose update image
@Thomas67 I just flash 3.0.9 transcoding its not working as well. Advanced button do nothing. Guys are you tested? Can I send you a log file to check it.
I have flashed the 3.1.0 but will put the 3.0.9 image in Multiboot and check again.
But it did work before i upgraded to 3.1.0
If you have a log please send it
Please remind me how can I export the log?
Simple:
1) Download to your pc.
2) Edit the downloaded file!
3) Select the whole content of the file.
4) CTRL-C ... for copy and CTRL-V to (paste copy) ...
You can use BBcode to post here!
Simple:
I ask how I export the log from the vu solo 2 not how I post at the forum.
