Long press blue button
bimbat
Hello experts,
I am using BH 2.1.7 on a Vu+ Duo2 tuner and I had a feature where when I long press the blue button I get some options, which included stoping a PIP (if one is running) and also moving it around the screen.
That option disappeared once I instaleld the QuickButton setup plugin and now all i see on long press is (No plugin assigned). I tried playing with all the properties of the newly installed plugin, but there is no option that would return the setting, which was default in the beginning.
The interesting part is that even if I deinstall the plugin, it does not return to the previous behaviour, rather still displays (No plugin assigned).
Do you know a way to go the old behavior of long pressing the blue button?
Thank you,
Todor
