loop trough
daif01
I have vu+duo blackhole 1.6.2.I have 4 lnb 13 e,4.8e and 0.8w via DISEqC 1.0 with one cable to receiver. tunner A is configurated 13e, 4.8e, 0.8w.Tunner B is not cifigurated.My question is :
is it possible to watch achannel and record another channel on another transporder.Thanks in advance.
Yes,
set Your second tuner like "loopthrought tuner A" and You will can do it.
Thank you for your reply.I have set second tunner "loopthrough tunner A" then i record a channel, i was able to wach some other channels, but i wasnt able to wach all others channels.Any one knows why?
Tanks in advance
Tanks in advance
Because the box filter the possible viewable channel such as polarization and SAT posizion.
Try to record a event on one SAT and try to view a channel on another SAT: you should see all channels of new satellite (I think)
Thank you for the fast reply .i will try it.
Tanks in advance
You can not view channels on other satellites if you do not have the dish or LNB connected to another tunner (tunner B).
It is true.
I said You what You max can get. You can watch 1 channel and record some other on same sattelite and You have possibility to use above 50% of channels on same sattelite.
