loosing connection
albalaji
I have vu solo 2 with latest blackhole image..
Why sometimes I loose connection between my Pc and Box ,my box and internet ? I'm using wifi usb.
thanks
thanks
May be if U change the Use DHCP to NO , then it will use one IP all the time!
Hi, i have Duo2 and i to lose mine conections some times.
I have fast ip and inbuild wifi usb conection.
This not happens every day but still it is not good.
I can´t have fast line yet to the router, later in the sommer i will get some cat 6 on the house building.
