Lost 80%
patn
Hello. Has a duo2 with blackhole on which I've lost 80% of storage on my harddrive :-( What can be wrong here?
Patn
Can you please supply more detailed information.
What does your Duo2 state the size of the hard drive is?
How much space does it state has been used, and is still free?
What make/model/size is your hard drive, and is it internal, or external?
Too few infos here: for instance, tell usa how did you partion and format it.
Anyway, it could be it is defective in some parts. But before saying that, be sure of how many recordings do you have there and check its status.
Another lack of info is: what image do you use (in order to tell you what command and menu would be helpful to understand the HDD situation)?
