lost half my plugins on solo 2
2wild2tame
hi guys!
i just mismanipulted dcc and erased half my plugins( ***** info- webinterface etc...).the problem is when i wanted to instal a plgin,the opration goes well but the plguin doesn't appear .
any idea or suggestion is really welcome and thanks a lot for your help and patience
note : i am using a solo 2 with black hole 2.0.3 hyperspace
hi guys!
If the plugin is in the Black Hole Speed ​​UP (blue>>Blue button)
then first disable and later enable.
If the plugin is in the Addons Uninstall Panel (green >>yellow>>Addons Uninstall Panel
first uninstall it and then reinstall.
But the best solution is to reinstall image
