After some digging in the settings of BH 2.05, no futher details that wil help me.
But maybe there is some other problem, after reading in this forum about cam's i think there is maybe an other problem. What maybe helps i will discribe my configuration:
VU+ Duo2
2 tuners dvb s2
1 canaldigitaal card
duo LNB
2 cables in tuner
Config tuner A (Simple, DiSEqC A/B, A=19.2, B=19.2)
Tuner B = Tuner A
P.I.P is in FTA working fine, in canaldigitaal cam by switching to other canaldigitaal program there is a black screen small is fine. When recording a program in canaldigitaal 1 or 3 programs no problem, but if you switch to an other program in the same transponder you get a black screen. If you go back to the program that is recording than everyting is oke. In my memory i thought it was all working fine in the begin!?
Is there someone who can help me to find the solution????
