M3u files Help please!!!
poliv123
Hi all of you!!!!
I have an m3u file which i used to put via ftp mnt/net... in my uno with other images,and play well.
Now with blackhole 1.7.9 i did the same but not streaming.
How can i play m3u(free iptv channels) with the blackhole 1.7.9?
Which plugin shoul i use?Can you send me details please?
Please help thank you!!!!!!!
after u put the file there, what did you use to play it, ? also the m3u file is it rtmp / rtsp or http{hls} ?
When i use vti i put it in /mnt/net folder Then i open vti's media player ,choose the file and automaticly open ,in the playlist, the channel list.Then i press a channel and plays normaly(streaming).When i do this to blackhole ,the same happens, but the channels is not opening.I cant view the channel.Black screen.Can you help me!!!Thank you!!!
go to the enigma2 plugin forum wwwwwwwww.vuplus-community.net/board/threads/futubox-iptv-working-vu-uno-with-nstream-vod-plugin-with-no-dish.11543/#post-85540
you should also check with xbmc for windows http://xbmc.org/download/ to make sure your links in the m3u file are still valid,, on xbmc go to video / files // add file ,, put m3u file in a folder on destop add that folder and play ,,and if there password protected ie: the links in the file have ...?lpjfojhwefohfoiehfowrihfwoehf -- summin like that on the end of them u might be locked out , if the server has detected 2 channels being acsessed at the saame time ,, if thats the case change the password on the server ,, re download m3u file and try again , xbmc works with rtmp m3u files btw
