Romino
I like to change many small things in BH 2.1.5.
Small things that i like to accomplish:
Or need to change some XML file?
Also i like to compile an app i cant seem to find "Popcorn Time", but that i already sent a post in Tools.
Hopefully someone got a tip and i can use it for compile other apps that i like to create.
http://www.vuplus-community.net/board/threads/popcorn-time-create-app-from-source.22706/
Old issue that i had got:
Before when i add a timer, and accept the default times (0 mins before, and 0 mins after) it is not possible to add the program directly after.
I had to change the end timer to one minute less manually, or else they collide.
Was thinking of change the Endtime to -1 in /etc/enigma2/settings (default is "config.recording.margin_after=0").
Dont know if its possible to change to a negative settings there..
But it seems to work now without change that, so i leave it alone.
Thanks for reading about my small problems.
Im using an Duo2.
- After playback in your recordings (timers), i often press ´stop´ and then the box go back to last channel, but i like to change the settings so i remain in the recordings list instead.
- When using Multi QuickButton (2.7.5) ,in CoolTvGuide (v7.3.0) i like to go directly to "Cool Tiny Guide" but that has been removed and not possible to add, it is only possible to add other guide´s :-( , so i add another Guide mode and then i need to press many times on Yellow button for change (GuideSwitch), troublesome.
Im using an Duo2.
