Manual Install Bh packges and for ipk Manual Install Ipk packges
manica
the explanation on this thread to install the above applications do not work on the new openblackhole.
It is or not possible to install or the program have not the add on manger option?
i am using vu+duo2
thank in advance of your responce
i am using vu+duo2
Note necessary any manual to do that:
Make use of your rcu ( Remote Control Unity )
Press <GREEN> <YELLOW> <MANUAL INSTALL IPK PACKAGES> To install Ipk Packages
or
Press <GREEN> <YELLOW> <MANUAL INSTALL BH PACKAGES> To install tgz files
Best regards
thank you,
After install the
Open Black Hole Vu+ Duo2 0.1 i followed the steps and do not pop the addons menus
tried different combinations and nothing, never comes the addons menu
You have to make "USE "of an FTP tool ( Dreambox Control Center, Filezilla ... ) to comunicate via network with your STB and to upload files to it.
The files ipk, tgz, ... must be uploaded to /tmp/ directory or its the same to /var/tmp
If you don´t know howto use this tools ---> take a look to this guide ---> http://www.vuplus-community.net/board/threads/howto-connect-your-pc-to-your-vu-box-with-ftp.21220/
i know how to do that and i have Filezilla and i did put the **********.all.ipk file on the temp folder ( Open Black Hole Vu+ Duo2 0.1). the problem is how to acces to the addons menu to install the ipk file
i am using the OpenPLi but i love the open black Hole. sadly has no option to install ipk files
very pleased
regards
thank you jose
