Manual Scan for single satellite is searching forever
dimensionone
I have issue with the latest image. When I want to perform manual scan and search all transporters within single satellite, the search screen will appear, but there is no progress displayed. I let it run for 20 minutes and no progress. I scanned 23,5 Astra satellite. When I run manual scan for one transporter, it is working fine, although it is not showing any progress, but only after some time of running display list of found programs.
Something is not right.
Did you install a clean image, no backup ??
Is your antenna well set to Satellite
Have you correctly configured tuners ??
Scan works without problems.
Hi! Tried to update the file Satellite.xml
Hi, I have updated the image and then restored from backup. How can I upsate satelitte.xml? Where can I download the correct version?
