Max streaming channels
skywalker2
Hi all,
Usually I enjoy my duo2 while I'm working on PC. Normally I use the blackhole webif and VLC. Recently I tried to stream múltiple channels at the same time. The results: only 7 channels streaming at the same time under VLC. I would like to know if 7 channels is the top or if there is something wrong. I have a dual dvb-s2 tuner and I tried with channels on the same transponder.
Thx
Enviado desde mi Aquaris E6 mediante Tapatalk
Just tested on Solo2 last OBH - 7 channels max, no mathers 1 or more transponers. Sd or HD. I have and OS2+ receiver with openatv 4.2 and streams more than 12 channels. Strange...
Hi oldgraf,
Thx for your answer and interest. One question, do you use the same emu in both cases?
Regards
