MBC OFFICIAL CARD
Hello, yes you can use your card MBC without problems, I have the same card and I use it with my VU + SOLO2 and it works impeccable
I have MBC CARD only came with technosat receiver, for now i use 2 receivers, i want to cancel MBC receiver and use Ultimo for MBC HD chs, What do i need to add to get card works with Ultimo
Thanks.
Thanks.
that's true card came with technosat receiver T786 HD and now BD888 HD and think workin' only on it, but you can find also a CI of ICHD module with 3 years Subscription for the 6 HD channel of MBC and Al arabia HD for all receivers with CI
