Media Player frame rate settings
MrCobra0007
Hi all,
I recently bought a Vu+ Solo2 and i want to use is as a media player but i'm struggling with the frame rate settings, example, i wanna play a mkv file with 30fps so my tv has to go in 60hz mode and when in play a 25fps file my tv has to go in 50hz mode, but this is not happening a 30fps file stays my tv in the 50hz mode, can someone tell me how to chance to the correct setting because there are so many settings in this sat reciever.
Thanks in advance.
As far as I know there is no special video media player settings
but only A / V setings and Autoresolution settings for all ..
Look under Main Menu >> Setup >> System
How it works (if works) with MKV and media player I do not know.
Example in A/V settings you have Refresh Rate multi/50/60 hz
In general with multi you should have automatic control.
Try also with Autoresolution panel settings.
