Hi,
This is my first post, thanks for the good work.
I have a Mac formatted Hard disk and a solo2 box. Black hole media player does not 'see' it. Is there a solution to this?
Thank you
Thank you angelofsky for your reply.
I tried mounting the HD through Device Manager but again the media center does not see it. When I connect the HD, I only see a new empty partition in the media center i.e. containing only the 'folder' "List of Storage Devices". The files and folders are not listed.
root@vusolo2:~# cat /proc/filesystems
nodev sysfs
nodev rootfs
nodev bdev
nodev proc
nodev tmpfs
nodev devtmpfs
nodev sockfs
nodev usbfs
nodev pipefs
nodev anon_inodefs
nodev rpc_pipefs
nodev devpts
ext3
ext2
ext4
nodev ramfs
vfat
msdos
iso9660
nodev unionfs
nodev nfs
nodev nfsd
nodev cifs
ntfs
nodev autofs
udf
nodev mqueue
nodev mtd_inodefs
nodev ubifs
# CONFIG_HFS_FS is not set
# CONFIG_HFSPLUS_FS is not set
If you are using Mountain Lion, the issue should be due to the lack of samba on your Mac.Thank you angelofsky for your reply.
http://eduo.info/apps/smbup
I've not tested it, but you should solve the issue installing SMBUp on your Mac.
It's a free tool and you can download it from the following link:
Code:http://eduo.info/apps/smbup
If you install it, let us know if it works.
Hi, sorry, I connect through USB, not Network.
Still no solutions???![]()
