Mediaplayer2 on Kodi 16.1
salfordd
Hi Im running OpenBH 0.4 on a solo2,does anyone know if you can have mediaplayer2 as default mediaplayer in Kodi like you could do in xbmc.thanks
Hi could I do this to change the MediaPlayer in Kodi in openblackhole 0.6. Cheers
Probably yes, but you have to try with this "plugin.py" file.
Test it and reply ...
Note: The steps are the same pointed ... but use this file instead of the other for BlackHole 3.0.2F
Hi thanks for reply I've tried that but couldn't get it to work,and this is off topic but for some reason when I change the button layout in Kodi keymap.xml file(submenu,context menu) the remote control stops working in kodi thanks
