Mediaportal 7.3.1. Crash on Launch BH 2.1.7
wal18b2s
Any ideas?
/usr/lib/enigma2/python/Plugins/Extensions/MediaPortal/additions/mediatheken/zdf.py:422: SyntaxWarning: name 'pageTrigger' is used prior to global declaration
cannot open /proc/stb/audio/j1_mute(No such file or directory)
main thread is non-idle! display spinner!
warning, skin is missing element pv_emm in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element bul_no in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element biss_no in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element pv_ecm in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element button_cex in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element bul_ecm in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element dre_no in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element dre_emm in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element biss_emm in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element bul_emm in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element biss_ecm in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element pv_no in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element dre_ecm in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
have 1 video stream(s) (0209), and 3 audio stream(s) (02b1, 029d, 0289), and the pcr pid is 1ffe, and the text pid is 0249
decoder state: play, vpid=521, apid=669
[eDVBCIInterfaces] gotPMT
[AutoRes] determineContent
action -> OkCancelActions ok
okbuttonClick
[EPGC] start caching events(1450479081)
VIDEO_GET_EVENT - ok
[AutoRes] got event evVideoSizeChanged
nr_read 10712 nr_write 7586
sum 18298 prev_sum 18290
hdd was accessed since previous check!
[IDLE] 0 600 False
[AutoRes] got event evVideoProgressiveChanged
action -> WizardActions ok
Resetting stats
File "/usr/lib/enigma2/python/Components/ActionMap.py", line 46, in action
res = self.actions[action]()
File "/usr/lib/enigma2/python/Screens/PluginBrowser.py", line 66, in save
self.run()
File "/usr/lib/enigma2/python/Screens/PluginBrowser.py", line 70, in run
plugin(session=self.session)
File "/usr/lib/enigma2/python/Plugins/Extensions/MediaPortal/plugin.py", line 3471, in MPmain
startMP(session)
File "/usr/lib/enigma2/python/Plugins/Extensions/MediaPortal/plugin.py", line 3481, in startMP
watcher.start()
File "/usr/lib/enigma2/python/Plugins/Extensions/MediaPortal/resources/twisted_hang.py", line 103, in start
self.lc.start(self.cancel_interval)
File "/usr/lib/python2.7/site-packages/twisted/internet/task.py", line 162, in start
raise ValueError, "interval must be >= 0"
ValueError: interval must be >= 0
(PyObject_CallObject(<bound method ActionMap.action of <Components.ActionMap.ActionMap instance at 0x2c66990>>,('WizardActions', 'ok')) failed)
getResolvedKey config.crash.details failed !! (Typo??)
I think you have problem with NOWTV ????
The problem is linked to plugin and not image.
The author is active on VTI forum.
And before anyone asks, yes NOW TV is broken and will probably not even run, so it looks at least from currently.
The looks unfortunately not good, which seems to be the final end of NOWTV.
