mediaportal
Ftp an ipk version and manually install. Why would you not want the latest version?
Sent from my SM-G900F using Tapatalk
thanks artorius.do you ftp it through var or usr . all the latest versions doesnt have the adult section
well i have failed to enable it and ive tried almost everything there must be a secret ?
Open Mediaportal, press the epg button and you will be asked for the pin, 0000 the press menu and and switch from no - yes on the adult options.
Hy, is my first time, and sorry for my english, i have a problem install black hole images 2.1.7 e 3.0.4, and try to install media portal plugin. all the process is fine and installed,
but when i go to PLUGIN MENU' i cannot see in the list. in both images same problem. i try to format also the hdd. thanks guy!
