Mediatomb wrong ip address
alez
Vip
I have flashed today with the 1.4.5 BH image the my Vu+ Duo
I have found a possible issue:
when i start the mediatomb server, in web interface the files are linked to 192.168.0.106, it's not my ip.
I have tried to kill and start manually the mediatomb binary, and i have found which mediatomb start with this address.
I have correct the issue by editing the file
/etc/init.d/mediatomb
the line
ARGS="-a /media/hdd"
modified in
ARGS="-a /media/hdd -i 192.168.1.14"
this is my internal lan box's address, use your own
THIS IS WRONG PROCEDURE.
YOU HAVE NOT TO START MANUALLY MEDIATOMB BECAUSE IT WILL USE WRONG LOCATION CONFIG FILE.
YOU HAVE TO START MEDIATOMB BY PANEL AND YOU WILL FIND CONFIG FILE IN :
/.mediatomb/config.xml
