JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser .
ciao volevo installare il dlna e sul riavvio ho avuto schermo verde con vari percorsi però sempre per disco pieno
ho fatto df da root e mi da
root@vusolo2:/usr/lib/enigma2/python/Screens# df
Filesystem 1K-blocks Used Available Use% Mounted on
ubi0:rootfs 199436 197264 2172 99% /
devtmpfs 2048 112 1936 5% /dev
tmpfs 286576 268 286308 0% /var/volatile
udev 2048 112 1936 5% /dev
tmpfs 286576 0 286576 0% /dev/shm
/dev/sda2 1983276 286292 1594572 15% /media/usb
/dev/sda4 955252876 59134436 847587684 7% /media/hdd
/dev/sda1 1983276 26684 1854180 1% /media/downloads
/dev/sda3 1983276 3060 1877804 0% /media/video
qualche idea?
ho da poco messo il permanent time.shift ma lho mappato su hardisk
grazie
BlackHole Driver Specialist
qualche idea?
grazie
Root filesystem stracolmo.
1. cancelli qualche cosa che hai aggiunto e che ti ha riempito la flash e dopo usi gli universi
2. flashi ex-novo e poi usi gli universi
ho dei file dentro usr/lib/enigma2/python/ che sono da 20 mega
root@vusolo2:/usr/lib/enigma2/python# ls -la
drwxr-xr-x 7 root root 2632 Jul 13 14:26 .
drwxr-xr-x 3 root root 224 Jul 13 14:26 ..
drwxr-xr-x 2 root root 1384 Jul 7 15:07 Blackhole
drwxr-xr-x 5 root root 11448 Jun 22 2014 Components
-rw-r--r-- 1 root root 121 Jul 7 15:04 GlobalActions.py
-rw-r--r-- 1 root root 278 Jul 7 15:04 GlobalActions.pyo
-rw-r--r-- 1 root root 4600 Jul 7 15:04 Navigation.py
-rw-r--r-- 1 root root 5439 Jul 7 15:04 Navigation.pyo
-rw-r--r-- 1 root root 17 Jul 7 15:04 NavigationInstance.py
-rw-r--r-- 1 root root 160 Jul 7 15:04 NavigationInstance.pyo
drwxr-xr-x 5 root root 664 Jul 13 14:26 Plugins
-rw-r--r-- 1 root root 26217 Jul 7 15:04 RecordTimer.py
-rw-r--r-- 1 root root 23421 Jul 7 15:04 RecordTimer.pyo
drwxr-xr-x 2 root root 10328 Jul 7 15:07 Screens
-rw-r--r-- 1 root root 829 Jul 7 15:04 ServiceReference.py
-rw-r--r-- 1 root root 2177 Jul 7 15:04 ServiceReference.pyo
-rw-r--r-- 1 root root 2279 Jul 7 15:04 SleepTimer.py
-rw-r--r-- 1 root root 3932 Jul 7 15:04 SleepTimer.pyo
drwxr-xr-x 2 root root 3296 Jul 7 15:07 Tools
-rwxr-xr-x 1 root root 14904 Aug 28 13:56 boxbranding.so
-rw-r--r-- 1 root root 5262 Jul 7 15:04 e2reactor.py
-rw-r--r-- 1 root root 5856 Jul 7 15:04 e2reactor.pyo
-rw-r--r-- 1 root root 188942 Jul 7 15:04 enigma.py
-rw-r--r-- 1 root root 214365 Jul 7 15:04 enigma.pyo
-rw-r--r-- 1 root root 5540 Jul 7 15:04 keyids.py
-rw-r--r-- 1 root root 8456 Jul 7 15:04 keyids.pyo
-rw-r--r-- 1 root root 2079 Jul 7 15:04 keymapparser.py
-rw-r--r-- 1 root root 2794 Jul 7 15:04 keymapparser.pyo
-rw-r--r-- 1 root root 16902 Jul 7 15:04 mytest.py
-rw-r--r-- 1 root root 18716 Jul 7 15:04 mytest.pyo
-rw-r--r-- 1 root root 21486 Jul 7 15:04 skin.py
-rw-r--r-- 1 root root 19003 Jul 7 15:04 skin.pyo
-rw-r--r-- 1 root root 8704 Jul 7 15:04 timer.py
-rw-r--r-- 1 root root 8330 Jul 7 15:04 timer.pyo
-rw-r--r-- 1 root root 102 Jul 7 15:04 tools.py
-rw-r--r-- 1 root root 476 Jul 7 15:04 tools.pyo
li posso eliminare?
li posso eliminare?
A parte che non sono mega ma bytes ...
Prova con
Mi accodo a questa discussione per porre la seguente domanda:
da telecomando è possibile verificare lo spazio disponibile sulla memoria flash?
L'altro giorno ho accidentalmente dato l'ok al download di alcuni picon per DTT e non ho letto se la directory era la solita Media/Usb/Picon.
Credo di si ma vorrei verificare.
fallo da telnet, che eviti di cercare tanto.
comando:
df -h
Blu - Giallo.
90% il path di installazione è /media/usb per i package di picon prelevabili dal server.
