Meoboot Boot Screen Issues
Sharshoor
My problems that the boot screen with 4 Images and during the booting I cant change the and select the image I need to boot from only from plugin its self I can select the image, any one faced this issues with latest BH2.7, my VU+ Ultimo with 1T HDD and Sony USB 8GB, flash image latest BH and in multiboot VIT, VIX, BH, modified PLI.
Can you see the list of installed images during boot on Meoboot screen ?
Did you upgraded your image in flash ?
Try to reinstall MeoBoot, this solved same problem here after an image upgrade.
Yes I can see the list of installed images , no upgrade for flash image , fresh install and I removed and reinstall meoboot and its the same, I tried new USB stick KS type 4GB and the same result! this is only with BH2.7 and BH 2.6 all its OK , any though or help.
I believe that there is no support for Meoboot plugin , finally I managed to install patched Meoboot for dreambox and all running fine.
