Meoboot deactivation
hazzhass
I no longer use meoboot, as I removed external flash.. My question is how to deactivate meoboot, (without completely removing it), so I do not see the meoboot startup picture, when rebooting my solo2
Use 2xBlue>BH Speed up>disable meoboot!
Does this mean It will also disappear from plugins list??
I do'nt want that, just want it to go back Virgin!
It's better follow A911's indications: if you'll want to enable again you'll can do it only enabling the plugin again.
