MeoBoot on Hard Drive vs USB
scipion
Hello,
I have never used MeoBoot and Multiboot.
is it safe to try it on Hard Drive (my USB slots are used by DVB-T and for universe storage)?
Is there advantages in using one or other way (HD vs USB)?
Thanks.
If you use your HDD for Meoboot, it will be always running.
You may create two (or more) partitions on your usb stick and use one for universe and one for Meoboot.
There is no risk to loose data when we install it on an existing HDD, right?
For the USB, is it possible to I do this without loosing the existing partition used for universe? how?
Right!
You need to format the usb stick before to create new partitions, therefore all the data stored on it will be deleted.
I am wondering if we can just play with linux symbolic links to have meoboot installed on the same USB and partition as the one used by universe.
I'll try and see if it works.
