meoboot wlan problems with new images
Alex0202
Hi there,
yesterday i installed the new BH Image 2.0.3 to Meoboot on my Vu+ UNO. But i have a wlan problem. In the Network-Menu only the LAN-Settings are shown. Nothing to change it to my WLAN-Adapter.
First, i thought my wlan adapter (LogiLink something) isn't supported by the new image. Therefore i want to test other Images like VTI, OpenPli, Zebradem. But on no image it was possible to change the Network from LAN to WLAN. So i'm not able to get an internet connection.
My standard Image (BH 2.0.2 E), which is installed on Meoboot works very well with my WLAN Adapter.
I tried to install new Images to Meoboot with copying the settings to it and without. Nothing worked :(
Is this a known Problem with Meoboot or is this problem due to using the LogiLink WLAN-Stick? Are there any possibilities to fix it?
Thank you.
At last, i want to say, that the BH-Images are the best image, i used. Definitely no problems. All is working how it should. Except meoboot with WLAN ;)
Thanks for all :)
I've moved your thread in the wifi section.
Look into my stick post "How to report problems" in this area and post here the debug file
We are working hard to definitively make stronger the wifi support
