Minidlna Server issue
denon54
Hi all,
I would like to let you infor about some test i did these last few days about setting up Minidlna on my Vu+duo2 and my old Ultimo.
First of all, for months i made a lot of test with my ultimo, and never got luck to make it work correctly!
I mean with Ultimo with latest firmware from BH2.0.7, i succeeded to set it up, and thus i finally could see
on my "Plasma Panasonic dlna ready" all folder from my ultimo, i mean folders "bouqet tv & bouquet radio,
problem is that when i select a tv channel in one of these bouquet, i then got a message on tv saying Please wait for about 30sec, then after file unreadable.
So i thought it was due to an old firmware about my tv and upgraded it to latest version, after that i still had got same message Unreadable.
Then, a few days ago i finally got my brand new Vu+duo2 and i set it up with exactly the same option and settings, and there magic works i got my channel in streaming on my tv, so it wasn't a problem with television firmware nor a misconfiguration but i finally had to admit it has something to do with power of the cpu or hardware from that Vu+duo2.
Does that mean that all model from VU+ except duo2/solo2 are unable to stream over adlna network ?
or did i miss something? ask you all guys if you have a ny explanation about that phenomenon.
Secondly, i notices somethnig else weird ! i can now as i explain see channel over dlna network up to my tv,
but only if i select a FTA channel, when i tried to do the same with a channel that belong to my subscription card screen remain black.
I would very appeciated if some of you could give me your point of view about all of this.
thank you toall of you, and above all thank you to BH coder and developper for your splendid work.
