Minix Usb Disk on VU+Solo2
hanso77
Hi everybody I need help to configure a network connection between a Minix X7 with a USB disk and a Vu Plus solo 2 with Black Hole 2.1.1
This is Minix X7 configurations IP 192.168.1.2 with samba installed and running (I can see the disk on Win 7 without problems) the disk is mounted with /mnt/usb_storage/USB_DISK0/Media/Elements
On Vu Plus SOLO2 if I go to Network Browser - Connections Lan I can see the Minix, try to insert username and password (the ones set to samba on minix)but if I try to expand the host nothing shows up, I tried to set up a new mount point network with this configuration:
Active: Enable
Local share name: MINIX
Mount type: CIFS share
Server IP: 192.168.1.2
Server share: /usb_storage/USB_DISK0/Media/Elements
Use as HDD replacement: no
Mount options: rw
Username: the one set on samba
Password: .the one set on samba
But no success I can’t see the disk .
So please give me some advice
Ciao
