missing a trick
martyd
epg,,, no matter what i seem to do if i select standby off a night in the morning the epg has cleared using opentv for the epg any advice ?????
You have to setup the device to save epg data file.
Blue Panel -> EPG Panel -> Global Settings:...
Afraid i am back cleared again this morning no epg,, sorted it all, updated it yesterday now its gone again
Sorry a911 don't really understand that?.....kingy is it ok to remove that by FTP or better to telnet?
Ok all gone again this morning, but restore worked fine, put it in standby last night and it had all cleared this morning
yes got rid of them done the update and they were ok until the auto update and that seems to be clearing the old and not replacing it with the new
sorted it, i was saving opentv for sky uk and italy to the hdd just too much i think,, went back to usb storage and its fine
