By default, using the skin default (Army NextGen HD Gradient), when you press the OK button or you change channel it appears on the infobar the name of the universe that you are using.To our dear skin-makers,
Could you please add on main info bar (the one we get when zapping) a logo or the name of the universe we are currently using ?
For now this info is just available when we press red button...
On skins developed for BH 1.7.4 there is already the name of the current unvierseTo our dear skin-makers,
Sorry guys but I use Eclipse HD (designed for BH 1.7.4), and unless I am blind I do not see the name of the universe ....
View attachment 7573View attachment 7574
At the moment, the universe name on infobar is available only for skin default.Sorry guys but I use Eclipse HD (designed for BH 1.7.4), and unless I am blind I do not see the name of the universe ....
Thanks for that Master Matrix10.
What about putting something into the clock ?
I'm sorry but I do not want to modify the skin because of this
universe info text is too long for this skin that I have make before,
we added universe to the BH image.
If we have the possibility to add small graphic information in the next images rather than long-Text i will add.
!I'm sorry but I do not want to modify the skin because of this
While waiting for your new release, I did the trick with the name of the current universe displayed into the clock:
I just modified "InfoBar.py" in /usr/lib/enigma2/python/screens in order to have only the name of universe instead of "in xxx universe"
Then called the widget "Universe" in your skin.xml pointing into the clock (under the clock hands).
Now the name of current universe appears automatically as the brand of the clock.
excellent,
now my clock has a name
if we can still sell
We share profits , OK
