missing pcsc-lite-lib in 3.0.5 opkg repository
coogh
today, installing the new bh 3.0.5 and starting the usual procedure to run pcsc reader, when I was trying to launch the command from telnet to install the pcsc-lite-lib, it gave me the error of unknown package (up to 3.0.4 never happened).
I tried to update repository and then list the packages, but nothing changed, not found. Is it possible to extract libs from 3.0.4 or a repository of other set top box? I don't know how to do it, Can anyone help me? Has something changed? Thank you very much.
root@vusolose:~# opkg install pcsc-lite-lib
Unknown package 'pcsc-lite-lib'.
Collected errors:
* opkg_install_cmd: Cannot install package pcsc-lite-lib.
