hi,
i cannot play my mkv file on my nas..
i mounted cifs but i cant play my mkv files in movies directory.
exp:terminators movies on hdd is seen m3u. files..
if i use filebrowser, i can play avi files,mp3 files,jpeg files..but mkv file is seeing m3u.files
hi guys, simple question, how to put your movies on your HDD when his already installed inside your box? i got some HD mkv movies but with usb it s impossible...
should i take the hdd out the box?
you can play MKV from USB but it's necessary a very very fast USB device to guarantee the minimum transfer rate.
I suggest an internal HDD to avoid every kind of problem
thanks
angelofsky1980
but i mean like i have some heavy files mkv( more then 4go) because solo2 read only the fat32 files...
i ve already try to put on my usb on ntfs but my solo2 didnt read this sort on files(ntfs)
