Hello, VU+ community,
could anybody post here the Motherboard description (part. no.: 00-1105901-01) here for me?
What am I solving, it is the fact, my VU+ Uno 4K SE:
is acting wear after it wakes from the standby status.
There are some white areas on the screen... and whole screen is blinking sometimes. It can be fixed by its restart, but after another run from standby status, it is here, again.
I asked the service in my country, what should it be? They told me, it is the CPU and it is caused by its high temperature. So, I want to add another active cooler on the top of its passive cooler to try to solve the issue. And I need to know, if this 5V active cooler could be connected through 4-pin P101 (marked by yellow in the attached picture), which is free on the motherboard?
Thank you.
is acting wear after it wakes from the standby status.There are some white areas on the screen... and whole screen is blinking sometimes. It can be fixed by its restart, but after another run from standby status, it is here, again.
Thank you.
