Motor not driving with both tuners.
mrdude2478
My motorised system works fine with BH 2.16 - however open BH 0.1 the motor doesn't switch sats properly.
I can get the motor to work - if I disable one tuner - so say I have 13e on tuner b, then switch to a channel on 19e - the motor works - then when I switch to a channel on 28e - tuner A activates - but the motor doesn't work (unless I loop through to tuner B).
It's determinately a software issue as my cables are fine - and everything works properly with other images.
Just thought the BH team should know.
