Motor or VU+ Duo Problem
fuji
My VU has developed a problem but I'm not sure if it's the receiver or my Cryptic Motor. Basically my dish keeps panning from East to West continuously. I've done the usual reset etc even updated Blackhole image. I've also checked all the connections but no luck.
If I go into Positioner Setup I can set the dish to 0 that works fine, Also positioner movement works I can move the dish manually however fine movement doesn't if I try this, again my dish just reverts to panning continuously. My motor is about 8 years old so I guess this could be the issue but I just wanted to check before spending out on a new one that the problem may be due to the receiver.
Any help would be appreciated.
Many Thanks
My tuner is confiqured advance using USALS DiSEqC 1.2 It's been working on this since I got my VU 18 months ago. I've not changed anything else, voltage mode etc so don't think it's anything wrong in the settings.
