Motor Problem
John Bailey
Hi all.
Loaded 1.7.3- all fine at first but now the dish motor will not move between Sats'.
The dish and motor are relatively new (installed last june)
I would appreciate any advice or a solution if anyone has experienced the same or similar problem.
I have tried re booting but this did not have any effect.
Tried a previous image but the Vu+ duo would not accept this.
Regards,
John
Hi all.
Regards,
John
Have you setted up correctly the image (Positioner -> your lat/long coordinates) and installed motorized settings?
Think I have identified the problem---------------Motor not working.
There is power from the VU+ Duo to the cable and power from the cable to the Dish Motor. Ergo, it must be a Motor fault.
Thanks to those that replied and offerd suggestions.
Best Regards,
John
