Motor Settings
teac532s
Hi all. I was given the above box to set up on a motorised system. The guy that owned the box had it on a fixed dish (Thor). I myself have an F3 box which is set on the motorised system using Usals and never misses a sat. However when I set the Vu up on my system it will not find the sats on the arc. It will pick them up but only if I manually move the dish through the positioner. I have tried it on Usals and Dis and I know i have set the lat and long correct because it is the same as my F3 box. What could I be doing wrong. I would have thought that once I told the Vu to use usals it would have found each sat the same as my F3 box. The image on the Vu is Vix. I reconnected my F3 and set it on 13 dg east , disconnected it and reconnected the Vu , set 13 dg east up , scanned and nothing. Any help appreciated
