Hi all.
I've recently encountered a problem when changing from a UK channel to a German one. The satellite moving symbol appears but the newly selected channel doesn't appear. When in the new channel I have to then open the tuner settings, save them and zap to the previous channel. This process shows the new channel, but it's never done this before.
The problem started after I had to re-flash my Solo2. I am running the BH 3.0.1 image, build 2015-11-18. Tuner configuration is Tuner A USALS, Tuner B equal to Tuner A.
Can anybody provide any advice as to how I can correct this error?
Thanks.
Thanks.
