Hello All,
I have a VU+ SOLO2 with blackhole 2.04 and a moterished dish setup - Moteck SG-2100A. I have tried these settings Henksat/Vhannibal/catseye.
My tuner configuration is USALS: Positioner - East/North - the correct longitude/latitude
When i goto menu -> setup --> service searching --> satfinder. I can position my dish selecting the right satellite for example 28.2 E.
After positioning with the satfinder i can zap through my channels of the bouquets 28.2E
When i zap for example to a channel of satelite position 13E the rotor is not responding.
it shows the icon of a sattelite dish that its busy moving to the 13E but the dish its not moving at all.
So changing to another sattelite in my setting bouqette the motor is not responding/moving to the channel change.
But if i do it manual with satfinder it goes to the correct satellite.
I followed also this tutorial i found here "tuner-config-tutorial-for-motor-dish-setup.12884" but still the same problem:
What setting in Blackhole is causing this ? Can anybody help me with this ?
